Ryzen 9000 leak shows 19% IPC gains
Specifically, an engineering sample with the OPN code "100-0000001290" has surfaced, indicating a peak boost frequency of 5.80 GHz, which is a notable 100 MHz increase over its predecessor, the Ryzen 9 7950X. This higher clock speed contributes to an impressive 19% increase in single-threaded performance compared to the Zen 4 architecture.
https://www.guru3d.com/story/new-amd-ryzen-9000-zen-5-cpu-leak-runs-58-ghz-and-faster-than-7950x/
Pretty impressive increase in this day and age.
That's a pretty solid number if true and in line with the IPC increases of the last 2 gens.
I am interested to see how Arrow Lake turns out, but I think a 9800X3D might make a nice upgrade from my 5900X.
As much as I'd love to say I've owned at least one Ryzen 9 of every gen, the 9800X3D would make more sense for all I use it for... 9900X sounds cooler and the ole Microcenter will have them on sale a lot sooner though so I might end up going that way again 🤣
CPU: 5900X + Optimus block
MOTHERBOARD: MSI X570 Ace
RAM: 32GB Oloy Blade 3600CL14
SSD/NVME: 1TB SN750 Black
SSD/NVME 2: 1TB SN750 Black
GPU: Reference 6950 XT
Haha, that is true. Might be a case of
Why Dont We Have Both GIF
If I could afford to buy both, I'd love to have them both.
I sold my 7900X to get a 7800X3D and don't regret that since it ended up in a dedicated 1440p gaming machine. In the main rig I lean towards not regressing on core count.
I'm not buying both because I need to put money away for CCW2025 in the Netherlands 🙂
  • Agreed 2
Hopefully it is. I have the upgrade itch on both laptops/desktop side just need right worthwhile hardware to release
N/A
CPU: 12900K with Sig V2
MOTHERBOARD: Z690 Hero
RAM: Gskill Trident Z5 5600 CL36
PSU: Seasonic Prime Titanium 1000Watt
GPU: Strix 3080TI with Optimus
SSD/NVME: Skhynix P41 2TB, SN850X 2TB
CASE: Caselabs S8
KEYBOARD: Mr. Suit Black Chroma
1.3k 826
On 31/05/2024 at 20:37, iamjanco said:
I was simply acknowledging that was a good idea; Lord knows what sort of shape I'll be in come 2025.
I take it day by day these days.
Off topic but I hope you feel better bud. Taking it day by day is all I can do too, and takes a lot of learning and proper self care.
Regarding the 19% improvement: somewhat impressive but I think its not really worth the upgrade for me, if it were on TSMCs 3nm node I would be more interested.
Yeah I very much figure that if you are already on an X3D Zen 4 chip, that there would be very little to no reason to upgrade. Keep in mind the IPC increase claimed is against Zen 4 non-X3D. I suspect the 7800X3D is going to hang right up there with launch Zen 5 just like the 5800X3D did with Launch Zen 4.
  • Agreed 2
