Water Cooling Club
20 minutes ago, damric said:
Suggestions on how to properly clean?
I only have ever used Mayhems Part #1. It's PH2, fill rad shake with all your might, leave and shake and turn over every 1 hour while awake. I usually leave it for 24 hours. Then MULTIPLE distilled flushes. Make sure the PH returns to 7.
Be careful on splitting 5 fans off the CPU header like you suggested in your video. I would definitely use a powered splitter for more than 3, even at reduced amperage.
What MOBO are you going to be running it off of?
56 minutes ago, damric said:
Got this radiator from @Avacado. For size comparison it's already the size of my HAF XB. Yes I'm tempted to just use it as a case lid :)
But I instead will try and build a mounting system with some aluminum angle.
That's hilarious, I'd love to see it used as a case lid just for the absurdity of it.
X470 Taichi. I could split them 3x3 I suppose.
This is everything going in.
You have 5 4 pin headers on your MOBO. No need to bunch them together!
x470.pdf
Yeah I haven't taped out what is routing where yet. I've 2 of the BIONX version of the P12 on the front and another P12 on the rear of the XB as well, so 13 fans and 2 pumps lol.
This is the preliminary video I made last week. Can't remember if I showed that or not.
Edited by damric
Should highly consider a Quadro or Octo. You won't regret it.
what is that?
1 minute ago, damric said:
what is that?
It's the gucchi bag of Fan/LED/Pump/Reporting control.
https://www.performance-pcs.com/fans-accessories/fan-control/aquacomputer-octo-fan-controller-for-pwm-fan.html
56 minutes ago, Avacado said:
Oh look at you. Yep getting that.
Edit: Ugh, out of stock everywhere except the OEM, which they want way too much to ship. I guess I'll be waiting and perhaps split the fans 3x3.
Edited by damric
Yeah this is part of the Blitz kit I mentioned and I should have been more specific, this is the rad one. I believe you can get it by itself.
Just so happens I have a brand new Octo if you are interested. Same deal as before, not looking to profit. Let me know.
Well whatever you spent and $10 to ship then?
The Splitty 9 Active is a nice little powered splitter if you are just looking to power some fans, and control them via the PWM header on the motherboard. https://modmymods.com/aquacomputer-splitty9-active-splitter-53231.html
Edited by tictoc
Added link
As my man Tic suggested, that is a great solution. Only consider an Octo or Quadro if you value the aqua computer software. It is fantastic. Just let me know. Gonna upload a video for ya.
Yeah I looked up specs on both and ofc I want the one with all the fancy sensors.
17 minutes ago, Avacado said:
That was an awesome video. Going to show Michele.
Time to go shopping on your parts bins.
I'll take one of those, one of those there, and yes that one too.
P.M. whatever I need to pay for that Octo, and I have a couple more questions as well.
4 hours ago, Avacado said:
love it, love Acool rads, they are so sexy. I want to know how well it cools.
I have 4 of their rads in 2 builds, I'm in love with them ?
3 hours ago, Avacado said:
COOL! Don't forget to clean that bad boy. ACool rads tend to have a bunch of leftover flux and such.
100% need to flush them!
Blitz kit or else I sometimes do a diluted white vinegar solution and then lots of flushing.
I used the Blitz kit too, good stuff.
Go ahead with the questions. I'll figure out the Octo later tonight.
I'm curious if you have any cheap DDR4 in that parts bin before I order some.
I see you keep lots of coolant mixes. Do you find that stuff worthwhile or is it just for looks? I'm asking because I'm also doing an ultra-cheap aluminum loop with some parts that might arrive in the next few months directly from China. It should be fun to test the near $1000 copper loop vs the ~$50 aluminum loop :)
Edited by damric
I don't unfortunately. All RAM is spoken for. Most of the Mayhems is Pastel White, that has been discontinued for XTR. The MMM clear was because there was no Mayhems XT-1 clear when I needed it. I might not ever use the white pastel.  I suspect that aluminum loop will probably cool within 10c of the copper.
Can you link me to that pastel white you aren't using? I want to see if it is compatible with aluminum. It might look good since the blocks have RGB built into them.
Hard as I tried, I can't find it listed. Looks like it is really EOL.
This is the blitz kit I was talking about.
https://www.performance-pcs.com/water-cooling/watercooling-fluids/watercooling-fluids-additives/mayhems-blitz-pro-cleaning-system-mbk1.html
This is the Mayhems clear.
https://www.performance-pcs.com/water-cooling/watercooling-fluids/watercooling-fluids-additives/mayhems-x1-coolant-1-liter-clear-mx1c1l.html
The MMM Clear is of Mayhems design (Mayhems created the formula) and is very good for less. This is my recommendation for clear coolant.
https://modmymods.com/modmymods-modwater-pc-coolant-clear-1-liter-mod-0275.html
I will work in a few L of mayhems white if you wish when I calculate the Octo. Just let me know.  Do know that I have had the pastel White turn opaque on a few occasions. Not sure why.
Is that this one? There's a warning on the bottom for aluminum.
https://mayhems.store/may_b2c/mayhems-pastel-v2-uv-white-opaque-premixed-coolant-1-litre.html
I'll just get the OCTO.
About to go eat.
