Water Cooling Club
56 minutes ago, Bastiaan_NL said:
Nice setup, and I thought I had a lot of hardware :classic_blink:
...yeah, you better get a move on re. upgrades ?
To be honest, I was looking at server hardware. I would love to have a giant pile of CPU's folding small units, cranking out 20 units an hour :classic_cool:
But first I need a basement with AC..
Thats the best part about basements, they don't need AC.
It has occurred to me that I should get grills for these fans. I have some mismatched grills from over the years but I would prefer matching ones, or one giant 1080 grill to protect the intake side of the blades.
Otherwise they worked fine when I tested them in PST 3x3 mode as @Avacado recommended.
Edit:
Shoot I'll kill 2 birds with 1 stone and get magnetic dust filter. Looks like I will have to get 3x360x120
https://www.amazon.com/Filter-4-72inch-Computer-Magnetic-2-Pack/dp/B08MPT5BSP
If someone has a better idea let me know
Edited by damric
CPU: Ryzen 7 5800X
MOTHERBOARD: B550 PG Velocita
RAM: 4x8GB Ballistix
...whaddya mean there's something wrong with my cable tube management ?
CPU: Ryzen 7 5800X
2 hours ago, Avacado said:
Wut is that?
...izz quad-SLI watercooling loop from many moons ago, stuffing a 'V12' into a moped frame, so to speak...was looking through some old build-pics as I'm getting parts in now for a new dual-loop setup....
...More recent builds are a bit more rational (below, that has only 4 pumps) - I probably follow that pattern more as the 'snake charmer' above...
8 minutes ago, Avacado said:
Good plan. So is the 1080 going to be exhaust then?
In that direction yes, but I'm making a gap between the top of the case and the filter/fans. I am going to leave extra tubing so I can set the rad box aside to access my case.
Edit: Kids love bugging me :)
Edited by damric
CPU: Ryzen 7 5800X
I really like the idea, but try to imagine case flow here. You will have how many intakes below? 3? and 9 exhaust fans with filters. Would create a negative pressure system within your case, starving the 1080 of cool air flow. I would propose the 1080 on top as intake with filters and case fans as exhaust. Would cool your components and create positive pressure in your case, helping to keep out dust.
CPU: Ryzen 7 5800X
Gotcha, so the top mounted rad won't effect caseflow.
Yeah it's going to mostly pull air from the sides
CPU: Ryzen 7 5800X
CPU: Ryzen 7 5800X
Looks good. Three Thoughts.
Looks like you have a g1/4 temp probe mounted in the top of your res, that is not a good place for accurate loop temp readings as there is a high chance of it not being completely submerged in your coolant. I can't remember if there were 3 ports on the 1080, but if there were that would be a good place, otherwise maybe a T junction would suffice somewhere in the loop.
I am not familiar with the X470 board, but most boards can turn off 2 SATA ports to give increased bandwidth on that 4x slot you mentioned that turns off when populated with an M.2 drive. I would read the manual to see if that is an option.
Rubber dampeners would help your concerns over pump vibration.
All builds are easy in theory and almost always in my builds, they go from "This should take a day" to "Holy * iv'e been working on this build for a week.
Actually that was an LED light I was messing around with. I don't have any temp probes, but if you link me to one I will get one :D
l'll check that out about the SATA. It's something I noticed when we were folding last week that the last slot was disabled by my 2nd NVMe drive.
I am looking at fabbing a rubber dampener. I just got my first pump clamp in place. It was tricky getting the holes drilled just right so I'm moving as slow as a snail. Interestingly enough I had randomly chose metric screws for all my aluminum angle stuff, and my M4 screws are exactly the same thread as the ones that came with the pump, just a bit longer, so I might end up using mine.
CPU: Ryzen 7 5800X
Out of stock everywhere of course. But this is my go to. Not expensive.
https://modmymods.com/alphacool-eiszapfen-temperature-sensor-plug-g1-4-deep-black-17365.html
https://www.performance-pcs.com/water-cooling/accessories-misc/alphacool-eiszapfen-temperature-sensor-plug-g1-4-deep-black-ac-17365.html
Chrome version is available on amazon for a bit more.
https://www.amazon.com/Alphacool-Eiszapfen-Temperature-Sensor-Chrome/dp/B01HQ8LJV2
You would be doing the OCTO a disservice by not have a loop temp sensor.
Aqua computer flow sensors are the bee's knees too.
https://www.performance-pcs.com/catalogsearch/result/index/?brand=232&q=flow+sensor
Where would that plug into and what software would read it?
Also:
CPU: Ryzen 7 5800X
Also:
Plugs into any g1/4 thread in your loop. I always rad mount them. Would plug into one of the 4 2 pin tsensor plugs on your shinny new OCTO.
Good because I'm looking at where the hell on my MOBO and I'm like hmmn would make a good CLR CMOS jumper ?
CPU: Ryzen 7 5800X
Seeing the light now. I will have water in here tonight to pressure test!
CPU: Ryzen 7 5800X
My AM4 Optimus block shipped yesterday. I just got my Alphacool 3070 block on Wednesday.
Still need to get two triple radiators, fans, and then figure out what I am doing for tubing and fittings. I think I can fit a thicker radiator on top with a thinner/standard radiator on the bottom. I don't do push/pull usually opting for just push.
LAWD. You going to pressure test WITH coolant in? ? You have worked so hard to not air test BEFORE adding coolant.
I use the one linked below. and instead of masturbating the mini pump, I attach a bike tire pump and she is pressurized in 2 pumps.
https://www.titanrig.com/ekwb-ek-leak-tester-0550ek010201on.html
Excited, we want pics!
