Phison: Enthusiast PCIe 5.0 SSDs Will Require Active Cooling
Modern enthusiast-grade solid-state drives (SSDs) deliver unbeatable performance. Still, they tend to produce a significant amount of heat, which can hurt performance and harm data on NAND flash chips. Phison says that as drives get more advanced, they are getting hotter too, so expect high-end PCIe Gen 5 SSDs to require active cooling using a fan (perhaps, like the one pictured above). Meanwhile, the company says that it is working on reducing the heat of its controllers as applications like notebooks or compact desktops cannot accommodate large coolers.
Looks like a podracer engine!
1.8k 2,031
Want!!!!!!!
Seriously, I just want the cooler.  I can hardly tell a difference with modern NVME drives, but man I want that pod racer cooler.
6 hours ago, ENTERPRISE said:
...should be interesting to see how they fit underneath modern motherboard shrouds. Also "only 70 C..." 😂 ...water-cooling gear for DDR5+ and PCIe 5+ should be a 'hot' seller soon.
Yeah we are going to see more and more WC tech coming out for DDR5/PCIe 5 components. Brace yourself!
waiting for the monsoon 4 stick RAM blocks. also, did we all forget about the lovely corsair dominator RAM fans that clip on?
EDIT : also remember. eventually all this will make in into your cellphone. waiting for a thicc asus phone.
Edited by PCSarge
1.8k 2,031
No need to wait.  Plenty of "thicc" phones out there already, just check out modern dumb phones and how they're making a comeback in 2022 lol.
I just want the pod racer cooler.  That's all. :lachen:
you have to attach it to a modern build in a retro atx beige case, and play episode 1 racer
And here I thought the few waterblocks I saw for nvme drives were a joke. Guess they were just thinking ahead. 🤣
Yeah that is actually a really cool looking cooler.
