Eyeing 11600KF Rocket Lake for my next build
WWW.EBAY.COM
Watercool gave the cold plate significantly thinner fins, which results in a larger surface and better heat dissipation. This new technology improves performance, flow rate, and reliability. System to simplify the...
WWW.EBAY.COM
Find many great new & used options and get the best deals for Intel Core i5-11600KF LGA1200 Processor at the best online prices at eBay! Free shipping for many products!
CPU Specs.
4.9GHz Turbo (target is 6.0GHz)
Case:
What do you guys think?
37 minutes ago, Avacado said:
I almost had a heart attack when I saw the case. I thought it was one of my favorites (Antec 900).
Man, that's a classic. Similar vibes for sure.
...why 11th? 11th gen sucks. get a cheaper locked 12th gen i3 or i5 and BCLK OC. then slap a used 12700K/12900K in it when 13th gen launches.
RAM: G.Skill DDR5-6800 CL34
SSD/NVME 2: Phison E19 512GB
SSD/NVME 3: Empty
Only certain boards can BCLK OC. Need a $500 board minimum. Unify-x, Apex, Hero, etc... Might as well wait for z790.
then just spend $50 more and get a 12600K or settle for MCE
$399 < $500
WWW.NEWEGG.COM
Buy MSI MEG Z690I UNIFY DDR5 LGA 1700 Intel Z690 SATA 6Gb/s Mini ITX Intel Motherboard with fast shipping and top-rated customer service. Once you know, you Newegg!
I win the internet today :wheee:
Edited by The Pook
SSD/NVME 3: Empty
I need to be able to both multi and BCLK OC for benchmarking. If I'm lacking one or the other it's not going to be good for benchmarking.
Just figured with prices down a bit I'd slowly work my way up to current tech. Starting with the best 14nm processor revision (rocket lake).
I am sure you'll be fine with anything older than 12th gen as far as BCLK/Multi OC. Do be aware that only certain boards provide the ability on the 12th gen (Require add-in clock generator). I went through 2 before finding one that actually could (MSI ACE, ASUS Strix). Neither of the boards had that ability. I know me and @Bastiaan_NL have both done work on non-K variant FSB OCing  (G7400/12100f/12400).
This article might help
https://www.hwcooling.net/en/overclocking-65w-alder-lake-processors-which-boards-can-do-it/
