Laptop Fans - besides cleaning, is it possible to get better RPM's with oiling or something?
GanjaSMK
MSI Raider GE75 - specifically the 10SE model (thanks Costco!)
Working well, but fans should be at 6000+ RPM on their 'full speed' mode.  Have cleaned them out a few times and get better temps/results and short of repasting (which I'm not inclined to do right now) is there anything I can do to get them back to their original 6000+ RPM's?  There are (2) fans one on each side and currently after last cleaning one is at 5500~ and the other at 5200~.  Am I doing it wrong? lol...
Oiling?
Swapping seems like huge project for little return investment . . .
Anyone have experience with this kinda thing?
If you can remove the fan blade from the pin it rests on you can try cleaning the pin. That would probably make a bigger difference than oil, but u could try adding a tiny bit of oil at that point if you want to.
  • 4 months later...
Oiling?
Bit of a late response, but the main way of getting a higher speed out of those fans typically lies with either software or a BIOS update. I would definitely start there.
$2000~
CPU: AMD Ryzen 7 5800X3D
MOTHERBOARD: ASRock B550M Steel Legend
GPU: Radeon 12GB RX 6700XT
RAM: 64GB G.Skill DDR4 3200 CL16
SSD/NVME: 512GB Sabrent Rocket (Gen 4) NVMe
SSD/NVME 2: 1TB WD Black (Gen 3) NVMe
SSD/NVME 3: 2TB Sabrent Rocket (Gen 3) NVMe
SSD/NVME 4: 2TB Samsung EVO (SATA)
$900
CPU: Intel Core i7-10875H (8C/16T @ 45w)
MOTHERBOARD: "Comet Lake" HM470 Chipset
RAM: 32GB TeamGroup DDR4 2933
GPU: 8GB Nvidia RTX 2070 (130w)
SSD/NVME: 1TB Sabrent Rocket (Gen 3)
SSD/NVME 2: 2TB Silicon Power A80 (Gen 3)
MONITOR: 17.3" 1920x1080 @ 144Hz
PSU: Chicony 240 Power Brick
Scalling with rpm is not linear i don't think that from 5200 to 6000 rpm their a big airflow difference. And normally fan without oil spin faster till they heat up and seize.
Cleaning the fans, oiling them, and re-timming the heatsinks always helps.....well, until its too late and it doesn't.  🤣
If the motor itself is starting to wear, no you'll never get the RPM's back.  If the above doesn't do enough, it MIGHT just be about time to do a full replacement.  Up to you of course, I mean its still working at 5200RPM, and you'd likely see a better temp drop from a TIM change than getting those extra 800 RPM's back.
While this is not a "helpful" post, your talking of fan improvements for me thinking of the below video. Problem is, it may make your laptop a little loud.
Did u monitor the rpm at full tilt when u first bought the laptop?  If so what was the original max rpm?  I'd replace the fans if u feel they aren't pulling rpm like before but u can tell if there is damage to the bearing if the fans are hard to turn by finger or feel any friction.  I would personally replace them and if u don't have a software option to force to full tilt while under load or creating a custom fan profile.  Just snip the PWM wires, the blue wire usually or u always have a red positive wire, a black ground wire, a yellow rpm sense wire, and a pwm wire could be green but usually is blue just cut it and forget about it on both fans if u cant control the fans by software in the operating system.  This will yield peak performance on the CPU & GPU on all tasks all the time.  Good luck
