970 EVO plus 1TB broken raid, help
Cerberus
3 Attachments
I had 2 1TB nvme's in raid 0 on my gaming pc, something broke the raid, i tired deleting the raid via bios (where it was set up) but it wouldn't delete. I bought a m.2 to usb to try and fix the drive but I cant get any where in acronis or disk management... the drive shows up as 2TB also.
any ideas (it also cant format)
CPU: AMD Ryzen 7 7800X3D
RAM: DDR5 6000
GPU: EVGA 3080TI
OTHER: OWC TB3 Dock
MONITOR: Dell S2716DG
MONITOR 2: Viewsonic 27"
what happens when you format/try to format?
CMD -> diskpart -> list disk -> select disk # (whatever it is)
CMD -> list volume -> select volume # (whatever the "1862" GB volume is) -> attributes volume clear hidden
then try to format (CMD -> diskpart -> list disk -> select disk # -> clean -> create partition primary -> format fs=ntfs) and then delete the array in the BIOS?
Edited by The Pook
RAM: G.Skill DDR5-6800 CL34
RAM: 96GB Mixed @ DDR4-????
SSD/NVME: WD SN850 1TB
OPERATING SYSTEM: Proxmox VE 9
You beat me to it.
Too much
CPU: 3600x
PSU: Seasonic PX-750
GPU: EVGA 3080 ti FTW3 Ultra
SSD/NVME: 2x WD SN750 500GB
CASE: Phanteks Evolv X
Xeb
CPU: Xeb
MOTHERBOARD: Xeb
RAM: Xeb
PSU: Xeb
GPU: Xeb
SSD/NVME: Xebbabyte
CASE: Xeb
FANS: Xeeeeeebbbbb
RAM: DDR5 6000
GPU: EVGA 3080TI
OTHER: OWC TB3 Dock
16 minutes ago, Cerberus said:
probably because the partition is RAW or WriteProtection is enabled (I assume the former).
Check HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
not in there ?
Edited by Cerberus
RAM: DDR5 6000
GPU: EVGA 3080TI
OTHER: OWC TB3 Dock
if it's not there then it's not enabled
Have you tried EaseUS Partition Master ? This program has saved me a few times with drives where others have failed miserably.
Also consider Minitool Partition Manager.
You could try this:
HDDGURU.COM
This freeware HDD Low Level Format utility can erase, Low-Level Format and re-certify a SATA, IDE, SAS, SCSI, SSD hard disk drive. Will also work with any USB and FIREWIRE external drive enclosures as...
I would also try this tool
HDDGURU.COM
This freeware HDD Wipe utility will erase and re-certify a SATA, IDE, SCSI, USB or Firewire hard disk drive. Plus, it supports most flash media, including SSD.
If that still doesn't work then maybe there is something wrong with the drive?
Too much
CPU: 3600x
Xeb
CPU: Xeb
MOTHERBOARD: Xeb
RAM: Xeb
PSU: Xeb
GPU: Xeb
SSD/NVME: Xebbabyte
CASE: Xeb
FANS: Xeeeeeebbbbb
  • 4 weeks later...
I'd avoid using any normal tools on an NVMe drive - download Samsung Magician and use the format tool in there, might need to write down the long code on the drive as the software will ask you to enter this when formatting.
Also make sure you've disabled Intel VMD/RST in the BIOS and set it back to AHCI mode before using any tools.
