DIY NAS/HomeServer.... Help in picking parts....
Memmento Mori
Long story short - my synology 212+ is stilli alive but is not up to date anymore for the tasks i would like to do have/do/test/playwith... So i was looking at some options and decided the best would be to DIY.... More cost efffective, better expansion/upgrade options and i could reuse some older HW which would give me better performance for less money.. Just a upfront infomation, its a project with not an urge and will take some time, but i thought i would be nice to have a thred where i can put my questions and get some advice... Hope you dont mind to share some opinions.. 😛
First Question would be Case related...
Found a local deal for a  used Fractal Design Torrent Compact White TG Clear in a mint condition,  for about 66,66 EUR (epic number after conversion - is it a sign? ) It has good airflow, and i like the looks but is it any good for a NAS? were thinking to buy some drive cages and mount them on the botom as there will be anyway no big VGA...  Any thoughs?  Y/N? pull the triger?
NoBodyKnow
CASE: CaseLabs SM8
66 Euros for Fractal Design Torrent Compact White TG Clear is really good price. But I don't think It will be really good for NAS. Since It's lacking 3.5 Drive slots and for NAS you will want atleast 6x of them If not +10x.
I don't know your local market but you should be able to buy old cases which should have more 3.5 Drive slots and be cheaper.
Edited by StrunkenCap
yes wight, but my idea is that for relative cheap and some time invested you can build in the cages.. eighter 3D printed adapter (Fan/HDD cage) and stock it up and you get a nice vented NAS which is as well visually appealing 😛  Or am i missing here something?
NoBodyKnow
CASE: CaseLabs SM8
my server was in a P400S with a bunch of added HDD cages but they just made the case/cabinet rattle. but if you can do it right then go for it
but no 5.25 would be my biggest beef ðŸ™ƒ
Ok, now you made me interested….Why do you need a 5.25 today? (Besides hotswap hdd cage)…
NoBodyKnow
CASE: CaseLabs SM8
Originally wanted it for my WH14NS40 with rip-friendly-firmware so I could rip BluRays directly to my NAS for Plex, then I got tired of doing that. Now just acquire the media from elsewhere ðŸ™ƒ
I moved from 6x4 to 2x14 when I changed cases and now I just use them for backups to external drives ~weekly. But there is a bunch of neat 5.25 bay stuff depending on what you want to do. Icy Dock makes a bunch.
true but not my case. 8 years ago i god an external dvd-drive and used it 2x since then… all is  asi ally oneline and the biggest problem is a storage now whre i can run backups of any devices …
will take a look at icy Dock saw already some addons they do.. thaks for the thougts and info ðŸ™‚
NoBodyKnow
CASE: CaseLabs SM8
I was thinking about something like this...
3.5" Vertical HDD Mount - Fan-Mounted
NoBodyKnow
CASE: CaseLabs SM8
How many drives slots do you need/want, 2.5" or 3.5"?
It looks like the torrent compact is wide enough that you could stack hdd cages up in the the front of the case. You would just need to make sure that whatever cages you use/print allow for airflow from the side.  I would definitely suggest using rubber dampers at all attachment points, but other than that, if you are willing to do a bit of modding you can stuff quite a few drives into most cases.
My backup server is about to be transplanted into a 22L case (about half the volume of the Torrent Compact), and that machine will have 6x16TB HDDs, mitx board, 10Gb nic, and an HBA. 😉
Look into a Corsair Vengeance C70. I have one empty and unused but it is missing some of the drive cages. From factory though I think it could fit 6 3.5" drives and a 5.25" drive (stick a 3.5" in). It is fairly plain but has really good airflow. Two fans on the side panel up to 140mm and fans on the back of the drive cages (they are supposed to blow towards the rear but if you turn them around they can cool the drives...) If you want visual appeal, stick some RGB fans on the side panel and throw in a light strip or something.
Hope this helps.
boyfriend GIF
  On 24/07/2023 at 15:38, Sir Beregond said:
boyfriend GIF
boyfriend GIF
Isn't it like picking your nose, where everyone just does it but lies about it?
¯\_(ツ)_/¯
  On 24/07/2023 at 17:16, ozlay said:
If you haven't chosen a CPU/motherboard yet. I'd recommend looking at used Eypc motherboard/CPU/Ram combos. Ebay is flooded with them. You can get a 32c/64t with a good motherboard and a bunch of ram for under $500.
well im a not even a casual user with a Synology DS211+, for this reason this combo what you recommend has 3x more cores then i use now on my 10900K 😄 and would be waste of power basically, too much overkill for my user scenario...
Im looking more into deals like 9600K with MSI Mortat mobo and 16 gig Memory for like 150 USD?  Not sure if eve that would be not to much overkill....
took a look at this guy here...
Hope this helps.
I like the military look of the case.. But idk - i probably got bewitched by fractal design and the Torrent model ... :scared_animatedfear: cant help my self...
hmmm that way to small as i want to reuse my Thermalright cooler... and i need a CPU cooler height of 170mm 😛
But hey im just getting in to the whole topic 🙂 But its very interesting, so i take m time and just gathering info i can.. If any other advice, please just share it 🙂
Thank you very much.
Edited by Memmento Mori
NoBodyKnow
CASE: CaseLabs SM8
overkill for what? what specifically are you going to use it for?
if's 95% NAS and you're only going to have Portainer or a few VMs then it's likely fine.
It is a pretty small case.  I was just using it as refernece to show that if you are going to do a bit of custom work, most any desktop case will work just fine.
If you go with the torrent you could get some of these rubber stackers: https://www.amazon.com/SEDNA-Hard-Disk-Rubber-Stand/dp/B07XYBKGWN/ref=sr_1_3?crid=20N040NWGAQVW&keywords=hard+drive+stacker&qid=1690330434&sprefix=hard+drive+stacker%2Caps%2C124&sr=8-3#customerReviews
Those require a bit of additional work if you are going to stack a bunch of drives, but in a situation like the torrent, you can install the drives with the cabling facing the motherboard tray.  That will make for a nice and clean look, allow the lower front intake fan to cool the drives, and dampen the vibrations from the mechanical drives.
Edited by tictoc
for the beginning it will be for sure just a nas and "Media" server..  Maybee later to hook up on it some cameras, but not expecting to run any sites, or hosting anything..
And i have to discover the world of True NAS and the other platforms what they offer and what i could do with it...  This here will be a bit of a sleeper thread 😄 as im slow progressing and its not urgent...
i like this..  having some experience how good they damping the vibrations?  I saw soe "silencer" trays for 3,5 HDD but from the informations i found it also increases the temps of an HDD by like 10 degrees..   and then i found as well some 3,5 HDD coolers but dont know what to think about it..  I want it as wel to be silent...
but yeah many things to discover for me in here 🙂
NoBodyKnow
CASE: CaseLabs SM8
any chance on moving away from TrueNAS and moving to a "true" Hypervisor like ESXi or Proxmox? Then you might want to look for a board with good IOMMU groups.
Doesn't really matter for TrueNAS + a few simple containers but if you want to virtualize all the things then it will. I tried moving my server to Proxmox but my board puts everything useful in one group 😞
consumer boards are all over the place and price doesn't really effect how good/bad the groups are (there are ~$120 boards with better groups than >$200) so it might be worth considering at least
Edited by The Pook
Since you like Fractal cases, the Define 7 in storage mode holds up to 14 3.5" + 4 2.5" drives. The XL version bumps that to 18 3.5 + 5 2.5" drives.  (you do need to buy extra drive trays to max out capacity)
I have a regular Define 7 with 8 drives currently. Fits big coolers as well. My Thermalright True Spirit 140 Power fits with room to spare.
AIL4fc_b7hxSEp_GGZpi_yL88tGQvn24n0QES-Mwijh4Cd25XYajSE3wQfijw5YmvElLdt8DpgJ6EXSX4ErYu0OOYBO2HyPn9ZTPbqkTjQtFHfn6h4xzdApbMzJQV_EO4SA8sxRAIV3R8qjQpJlMVxx0UOe19_p0GenT0pi3swd_Xv_TDB38Kr6R8MIbvvNy8vww9c9XSneTskCD5_CU0kU4IGuyQNfWMEutaEa0mrJ3eSAclhwElpGMSjp-NSjLok7ES6blvuQ5CvGgAnnT-2I3RiQdjClKILoM8NEzef5DsFRdI1HvjY5C_g-dtrDRgGkOQgXNS_GayqYSDMz6uH2rCF2mgnXRx5uU9tS-qmE2f_qNIwGdsj8nMW8F1xZrsRvufrgQFb-JdIOpTCyWQk6ihjqmmbx5UcnTHG_iT2uOGwbEgnk8StsmQmsJZDaLTSQJcJHjjQ4ckJs9nJVee3Pl-Gc3GyI77IRPhfjCqjrecwkMrorW5XKlICxf_ccc09iS22gSwH-RmJJJmFGcOQd7iD1t9NUljb5pt9gaL-gmndr4ENlJscjTgEFFAr-VNyK1MaKaKKckZyZBRZ6nP9Xc3_W7QAT7vq552zdA4UJp0JspxKjO_ihnhw7P2azX3SNdbCbf_XxsJeHaQpN6wP9jcj_OnlvlANDm7oue6s_eMMvXHpDYNo92Us4UTRehKRDMKC0CzPpDwQ3JViNx1vb2Bsb4cRDPWPfspG-xo-XU8b3GAjs59i2powJGl5bVXW99Kv5ZN7oGJoqGkY5MEm26f3CagRpjWgTX1Dtq5P31wGeWGvfH1S6CB4WpI-mNYcUQGp6NDdpizSMF1BlDmJ_fLMr2cOwQ2Yo96dMtZOfjoo1iAvj4lFEmXCzfBZHu_fINrg8gtbciYsrqKHn6Zg7glg=w655-h873-s-no?authuser=0
CPU: 5900X + Optimus block
MOTHERBOARD: MSI X570 Ace
RAM: 32GB Oloy Blade 3600CL14
SSD/NVME: 1TB SN750 Black
SSD/NVME 2: 1TB SN750 Black
  On 26/07/2023 at 13:18, The Pook said:
any chance on moving away from TrueNAS and moving to a "true" Hypervisor like ESXi or Proxmox? Then you might want to look for a board with good IMMOU groups.
:confused_waycon1::confused_confused1:
to be honest with you, first i have to take a look what Proxmox is and educate my self a bit..  But thank you for the hint! I will for sure consider it before i buy any HW (besides the case)...
Well i was to slow with the Torrent case and before i decided i was sold.... But im as well found another guy selling a Fractal Design Define 7 XL Black TG Light Tint for approx. 140 USD and as well a ventilated front cover approx. 46 USD..  Im tempted but on the other hand the case is too big for my use - not having the space for it as its a bit bigger then the "Compact" Torrent and for this price i could buy directly a new torrent... :silly_arrowhead: And in the end i would not use the capabilities of the case to the max which means waste of resources.... Im looking to have around 6-8 HDD , which is plenty space for my personal use....   As told - a "Pre"Basic user here 😄
NoBodyKnow
CASE: CaseLabs SM8
Fractal Design Node 804 is still the goat for a small NAS case. it only officially supports 6 3.5s but you can squeeze in 8+ with some ingenuity and/or a 3D printer
mATX though ðŸ˜—
mATX though ðŸ˜—
 True, even the guy in the video I posted earlier made it in this case and as well moded it a bit..  (3D printed front with a 200mm fan opening :D)
Anyway, i have true spirit power which is collecting just dust and would like to reuse it, for this reason i need a CPU cooler clearance of 171 mm ... For thi reason the torrent were looking ideal with the PSU in the upper area leaving the space for some HDD at the bottom.  Here as well a small inspiration ...
Link
Interesting to see the chipset cooler as this.. first time i see something like that but OK....
Anyway, if there is any other case having good Airflow with a PSU in the upper position, 171 mm CPU cooler headroom and the bottom free then please let me know...
NoBodyKnow
CASE: CaseLabs SM8
have you already tried PCPartPicker?
you aren't able to set a CPU cooler height requirement on the case page, but if you add your CPU cooler to your parts list and then go back to cases and enable the compatibility filter then it'll filter out cases that won't fit your cooler.
PCPARTPICKER.COM
or you could buy a new CPU cooler ðŸ™ƒ
thanks for the TIP... will take a look, but there are no cooler with a 170mm height.. anyway lets see what i will find 🙂  As told im not ahving any time pressure and i have to gather some infomations about the toppic of choosing the right platform for the NAS..   Thanks for the guidance 🙂
NoBodyKnow
CASE: CaseLabs SM8
