ASUS ROG Maximus Z790 Formula Motherboard Leaks Out: White, Water-Cooled, & Powerful
1.6k 943
The first images of the ASUS ROG Maximus Z790 Formula motherboard have surfaced, courtesy of leaker @wxnod, and they show the elegance of white motherboards, especially when ASUS does it, for its brand-new water-cooled premium design. The ASUS Formula series may not be the flagship of the lineup but it is regarded as an enthusiast product and with the preliminary prices that we've seen of the APEX ENCORE model, this variant should easily cost around $1000 US.
WCCFTECH.COM
ASUS's high-end ROG Maximus Z790 Formula motherboard has leaked and comes with a water-cooled design in a beautiful white-colored exterior.
7 hours ago, bonami2 said:
WCCFTECH.COM
Leak, leak, leak. How is EVERY piece of tech news a leak now? Cool board though. Thats a hard pass for me.
1.6k 943
They all in the leak tab of wccftech. And the other pic from asus don't match that one so am not sure 🤣
I know, I know, not blaming you, it's just annoying that everything is a leak now
snoozeville
754 era AsRock needs to swoop in and start making abominations again. like their janky dual socket 939 + 754 boards
Самые необычные материнские платы за всю историю компьютеров — часть №3
or at least boards with a more interesting mix of features. a DDR4 board with 10 GbE > $1300 motherboard with a waterclock  :sad-smile:
Is that an AI image? Its like the Intel 115x/1200 LGA latch with an AM4 CPU lol.
WWW.ASROCK.COM
Socket 754 for AMD Athlon™ 64 and Sempron processors; VIA K8M800 chipset; For advanced Socket754 64-bit AMD Athlon™ 64 and 32-bit Sempron processor; FSB 800MHz (1.6GT/s); Hyper-Transport...
THERETROWEB.COM
ASRock K8Upgrade-VM800 is a motherboard based on the VIA K8M800 chipset. Get specs, BIOS, documentation and more!
ASRock made a bunch of weird ones, some had both DDR2 and DDR3 (N68C-GS UCC, P43D1600Twins-1394, and P43D1600Twins) and they had a normie version of ^ with both sockets on a single board (K8 Combo-Z)
#MakeASRockGreatAgain
Edited by The Pook
2 minutes ago, iamjanco said:
^It's refreshing that he didn't ask me to send the board mentioned in the op with his 4090ti.
that doesn't sound like something I would do
and because of that you should reward me with a 4090 and/or 4090 Ti
1 hour ago, The Pook said:
WWW.ASROCK.COM
THERETROWEB.COM
Oh I was referring to the source of this "news".
If this is a Z790 board, then what the heck is this thing:
3 hours ago, The Pook said:
WWW.ASROCK.COM
THERETROWEB.COM
K8M800 754 ❤️ I have one of those
1.6k 943
On 04/10/2023 at 21:24, bonami2 said:
WCCFTECH.COM
...One of my fav Z790 boards, though it will have a short life span (Intel 14th gen) - one reason why I went the AM5 route recently ...btw, I do hope they fixed the Formula's 'corrosion issue' the Formula Z690 had, per Asus' site: "Developed in partnership with EK, the CrossChill VRM thermal solution on the ROG Maximus Z690 Formula uses a new electroless nickel plating. In certain configurations, this plating can break down, leading to galvanic corrosion inside the block's water channel."
