nkomax Thermalright Thermal Pad 12.8 W/mK
Avacado
3 Attachments
  On 13/03/2021 at 18:07, Avacado said:
So projeck for the day is to get the 5 Tesla's that will be on air completely renewed. Looks like it takes 1 package of 1.5mm for each card @ENTERPRISE Takes about 20-30 minutes per card to do it right. I found that using a TIM spreader will take off the old thermal tape without scratching the cooler.
Old. The TIM was so dry that it cracked and caked off when I tried to remove it!
Renewed.
Im a noob, accidentally ordered 0.5mm pads and not 1mm lol. Back to the shop !
...keep the 0.5 anyway - they might come in handy down the line (some EK blocks for example use 0.5, 1.0, 1.5, 2.0 etc). I used the Thermalright 1.0mm on the 3090 block and VRAM temps improved by 7 C or so - though I'm not sure how to delineate the breakdown between better mounting vs. better pads
Yeah will keep them for spares. Just finished ordering the new pads but stock levels suck so have to wait a while for stock to come in.
Luckily for you, you shouldn't need to order much, only one strip is 1.0 thick, you could stack 2 layers of 0.5 and it would be fine. If you have the 1.5mm, I would push forward.
Yeah may stack them, though I did already order a load, either way I will have lots of spares haha.
You just turned my Friyay into a Fryneigh. No one wants to hear about your "Load" E. E before load, e after load.
You are a bad person lol.
