On 15/01/2022 at 09:16, iamjanco said:
We might be neighbors of a sort if you're in Saranac Lake. I'm in ETown.
@AvacadoOnly if your mom was in what was West Germany back in the day (I got around a lot back then and made more than my fair share of moves, rhetorically & figuratively speaking) 😎
@The Pook I'm nol talking to you until you make me number 2 again.
I think we are neighbors then!. You are welcome to stop by and check out my setup here any time. I think you are about 50 minutes from me. And you dont have to wear a mask! lol
On 14/01/2022 at 19:18, SamsTechStuff said:
Fwiw, I run this rig stock always, and dont typically like to go to 1.45v on Ryzen chips even for the 3 minutes I used to close tasks and run this benchmark. Not sure I want to raise the vcore higher.
I would need to make it through the bench at 4.6ghz all core or at least half of them at 4.6ghz and half at 4.5ghz in order to beat those dual Xeons...but I'm close, we'll see 🙂
But for now here is my 4.5GHz 3900xt run, 558/9199.5.
Great looking PC, and those numbers you posted are very good. That processor you have is definitely a beast. But my z820 wont give up this fight 😉 I have at least one more card to play, and nine lives to go along with that. lol
On 15/01/2022 at 15:59, Bastiaan_NL said:
Update before @Storm-Chaser updates the previous submission 😄
670.2 single and 6774.5 multi, 7444.7 total with 102 bclk 4947mhz is the max I've seen. Another 93.2 points..
Nice run! those are definitely good benching speeds
Leaderboard Update....
Thanks! I'm not one for RGB, the cleaner look is good for me. This is my production machine, sadly the way my office is setup I cannot see the window of the PC with any of the configurations the Dark Base 700 supports. The 5600X rig I ran has no case currently and live on a cardboard box 😅.
I quite like this CPU, I'll be on it for a good long while. If you catch up and pass me, I'll find the cores that can go higher and Price is Right you! 😁 Awesome work with your 9600KF rig btw, that's definitely slick and I've been watching / looking forward to the updates!
CPU: Ryzen 7700X
How do you like the BeQuiet PureLoop ? I've picked one up for an office machine in March last year and really like it.
As to RGB, I find it harder to come by equipment that doesn't have it anyway whether I like it or not, but I made peace with it by setting everything to Cherenkov radiation blue 😛- it 'works' when the smoked glass panels are on.
It's a very unique AIO and it performs well so, I like it quite a bit actually. Being able to refill this AIO basically means I can use it for quite some time at nearly the same original cooling performance levels which I like. I have only tested it as a top mount with the push fan configuration - at some point I will do push + pull for that little extra I can extract to help speed up video exports. Even 1 or 2 additional 25mhz increments across the cores (auto overclock + PBO auto) during an export that takes an hour or so would be a benefit that would justify the cost of x3 fans to me. I would like to test the newer v2 but it is not available in the US (likely due to the Asetek patent issue?).
The main cooling issue I have is cleaning dust and cat hair from the intake areas 😅. Sometimes I watch the cat walk over to the computer and just rub against the front grated/mesh area and think, that's awesome..... ha.
EDIT: Yeah, RGB-free parts have become somewhat rarer - I agree, if you can get a color you like, it can be a nice addition. This rig will be set and forget soon enough (was assembled just before the holidays). Perhaps when I move my test rig into some case I'll think through the color scheme.
Edited by SamsTechStuff
CPU: Ryzen 7700X
The main cooling issue I have is cleaning dust and cat hair from the intake areas 😅. Sometime I watch the cat walk over to the computer and just rub against the front and think, awesome, lol.
...blame it on the cat, why don't you 😁
I like the refill option as well, though I cleaned and re-filled an old TT 240 (9 years and running now) not that long ago by taking the Asetek cold plate off.
As to the BeQuiet PureLoop, I used it first on an oc'ed 8c/16t Intel 5960X quad-c, followed by a 3950X and then 5950X while I was building up the custom w-loops for those two.  For the 16c/32t CPUs, I took the regular BeQuiet fans off and mounted 6x Arctic P12s psts in push-pull...the regular fans are decent enough performers, but Arctic P12 pst in push-pull made a clear difference - enough to allow the system to boost to higher sustained clocks.
Haha, the cooling performance hinges  on her cheek rubbing activity 🙂
Interesting selection of CPUs there - good to know about the P12's on the PureLoop. The Arctic fan bundles seem like some of the best value fan buys around. I was considering using these in the Rosewill RSV-L4500 servers I have in my rack, each run x2 fan trays with x3 fans each and I have x3 L4500 based servers currently. The Rosewill fans are ok but from what I have seen the P12s will be a bit better. Some of these fans are quite old and tired as well (thinking of my first chassis). Also, 4 pin molex is not my favorite.
CPU: Ryzen 7700X
Arctic P12 bundles ? Don't know what you mean 😉
The Arctic P12 psts are not only a great deal, their performance is really good...I replaced a whole bunch of older but still fav GentleTyphoon AP 29 3K rpm fans (and some Sunon 5k rpm server fans) with the Arctic P12s in push-pull on custom loops as well...in push-pull, they perform about the same as a single GT at full song, but are way quieter, if not near-silent. Their top speed is around 1850 rpm, with 1200 rpm 'default' per bios. I still adore the GTs, I just don't want to hear them...
  Reveal hidden contents
Wow, that's some serious air displacement power! I might end up acquiring as many as you 😀
CPU: Ryzen 7700X
Okay here is the z820 with two E5 2696 v2 processors, this is probably my best result with this rig. It's as high as it's going to go. @SamsTechStuff not sure if this gets me back ahead of your 12-core rig but at least it's somewhat more competitive than my last result (I will calculate scores tomorrow). All core turbo for this rig is 3,1GHz and it has factory water cooling. You can see here I have it compared to a 1950X for reference purposes.
2480808
Here is my high maintenance heatkiller water block (on the 9600KF)
Here is a slightly better result with said 9600KF in terms of pure clock speed. Probably don't want to go much higher on voltage, even though temps are under control.... it's okay though Im not worried about the processor. They are only about $150 used and most of them will OC like a champ.
screenshot of CPU-Z validation for Dump [97vmq5] - Submitted by  Storm-Chaser  - 2022-01-03 08:14:39
:wheee: I got it running kinda!!! :wheee:
2480808
Looks like you got me beat! I'll have to rerun the per ccd/ccx testing to see which can exceed 4.5GHz. Awesome result!
That is quite good for the 9600KF! How much power does it consume at that level during this test?
CPU: Ryzen 7700X
Thanks 🙂
You missed my best submission though 😂
On 14/01/2022 at 18:23, Bastiaan_NL said:
3950x all stock 543.4 single and 10916.1 multi, 11459.5 total.
I finished this system yesterday, installed windows and F@H and that's about it.
Maybe I'll find some time to mess with it this weekend to see what I can improve.
[edit before posting 😂]
Could not resists and did some minor cleaning:
Still stock in bios, 560.5 single 11179.0 multi, 11739.5. A difference of 280 points for 5 minutes of work..
1 hour ago, Bastiaan_NL said:
Thanks 🙂
lol I need you guys to keep the leaderboard in check. Im doing this comp with one monitor so things can get lost in the shuffle. Please examine your submission and let me know if something is out of place or missing.
During the CPUz benchmark it's about 130W. However, if I'm running AVX I've see much higher. About 180 W to be precise, but still no where near the limit of my cooling system. I run the system at 5.2GHz 24/7. I can actually ramp the fans down to low and I still can pass a torture test at that speed with the fans set static at about 500 rpm.
No problem at all, I was expecting some of our benchmarks to get lost in all the replies here 🙂
Very impressive. You are well on your way! 😅
The Opteron 200 series were more server oriented as those were for socket 940, which was capable of multiple sockets on one board.  The Opteron 100 series were for Socket 939 which was an enthusiast platform.  Think of it like people putting Xeons in their 775 boards or 1366 boards back in the day.  It's the same exact thing as running the FX 60 or an Athlon x2 4400+.  Just a neater name lol.  They tended to overclock like mad too, 3GHz daily was impressive back then (I'm still trying to wrangle that 3GHz stable on that rig now).
Sorry, just a daily dose of AMD history. 🙂
EDIT:  I think that score's pretty good actually.  I'm beating a "quad core" on the list, and keeping right up with the Core 2 Duo on the list there.  Heck, I'm beating the Athlon II which was a weakened Phenom II processor (no L3 cache).  A couple of those were mobile CPU's, but still.  I'm happy with that result!
I use 9x 120mm P-fans pushing into the 1080 copper rad I bought from Avacado last year. Do you think adding 9x pull fans will make a difference? If so, would the P-fans be best for pulling or should I get the F-fans for that?
...temp changes of push-pull will depend on components and current idle vs load scenarios. In my case, using triple core copper rads (64mm thick +-) and fairly tight fpi meant that push-pull was more or less a given. Also, you can move a lot of air with push-pull w/o annoyingly high and loud rpms.
For push-pull, you always want to use the same model of fan.
Since I was bored and decided to wipe my laptop too, here's another run in the faster rigs section. 🙂  I didn't bother doing the overclock on it so its still in the 15w power envelope.  Overclocking it, it absolutely will stay at 3.6GHz all the time if I need it to, but sadly I've damaged my battery from doing that. :lachen:
I swear it's so painful coming from a good sample low end CPU to a mediocre sample high end CPU. This pig 2700x just hates to overclock at all, eats voltage, and runs hot asf compared to that last 1600AF I tested. The best I could do was +voltage offset with +2% base clock on top of "Core Performance Boost". For some reason enabling XFR just makes the motherboard hang with an E6 code no matter what I have tried, and I have sadly put more than 8 hours into this endeavor today.
507 / 5468.1
VALID.X86.FR
[9lm8g9] Validated Dump by damric (2022-01-19 00:02:42) - MB: ASRock X470 Taichi - RAM: 32768 MB
