Distilled Water out of stock everywhere?
Is distilled water out of stock in your area?
11 members have voted
  1. 1. Is distilled water out of stock in your area?
    • Yes
      1
    • No
      10
So I was getting the last of the parts I needed and wanted to get started on my Mayhems kit and flushing.
But then my last road block to actually starting this project is....no distilled water in stock anywhere? What the heck!
Curious if other folks are seeing that issue in their area and what fellow water coolers are using instead?
Interesting, all out of stock here except supposedly one Walmart clear on the other side of town. I looked at 2 grocery stores, 2 Walmarts, 3 pharmacies, and a Target by me. All out.
Fine in Texas, might just be your local area.
way too mu
CPU: AMD Ryzen 9 5950X
GPU: ASRock 6900XT
MOTHERBOARD: ASRock X570 Steel Legend
RAM: G.Skill Ripjaws V 64GB (4 x 16GB) DDR4-3600 PC4-28800 CL16 Dual Channel Desktop Memory Kit F4-3600C16D-32GVKC - Black
PSU: SeaSonic FOCUS Plus Gold 1000 W 80+ Gold
SSD/NVME: Samsung 980 Pro 2 TB M.2-2280
SSD/NVME 2: Samsung 850 evo 1TB SATA SSD
CASE: Fractal Torrent ATX Mid tower
Good to know, thanks.
I haven't checked distilled in a while, but regular bottled water is in fine supply here so I'd imagine distilled would be the same.  Water aisles usually have plenty.  It's been mostly Gatorade and Lunchables, and weirdly enough meats that have been out of stock around here.  Mostly beef.  Easy to find turkey, ham, and chicken.
How interesting. Yeah I have at times noticed a lack of beef here as well.
As for water, there's no shortage of regular drinking water. It seems to specifically be distilled that nobody has.
I'm due for a grocery store run here soon anyway, I'll check next time I'm at the store.  You have me curious now lol.
1 hour ago, Diffident said:
Seen plenty of distilled in Walmart.  I just recently bought 6 gallons....but I'm using that for a radiator flush in my truck, not my computer. 😛
Nice. I gotta do a coolant change in my car as well in about 9k more miles per the maintenance schedule.
I just got back from town and all stores I went it were well supplied as well, so hopefully your store will have more soon.  That reminds me though, I need to order some of my coolant... I haven't flushed it in 3 years 😱... although from the see through ports all looks well... honestly, I can't believe this loop is still going, it's about a decade old and was used on my old FX 8350 and later the 9590 I tried to kill.
yeeeah thanks for reminding me of the flush i need to do and the coolant i cant afford #collegelife
Guess its just my area then, thanks.
A couple months ago I experienced the same thing. Went to 4-5 stores before I found any. Noticed stock was normal the other day when I was at my usual grocery store.
Fortunately no issue on my end.  In montgomery alabama we had it everywhere, moved 900 miles north (Kansas City, MO) and there hasn't been an issue here either.  Which was good, since it was greatly needed to get back up and running.
CPU: I9-9900K
MOTHERBOARD: Asus Z390-E
RAM: 64Gb Trident DDR4 3200
GPU: GB 1070GTX Gaming
SSD/NVME: WD Black NVMe 1Tb
SSD/NVME 2: Samsung 1Tb
  • 2 months later...
I found one store that seems to regularly stock it (but usually doesn't have much on shelf at a time), while the rest around here have been out of distilled ever since I made this thread. No idea what's going on around here then.
15 hours ago, Avacado said:
I offer $1, must be free shipping too.
🤣 People should just make their own. It's pretty easy.
Don't you need a distiller, or is there a MacGyver way to do it?
Big pot of water with a bowl on top of the water and a lid upside down on the pot that seals the pot and makes the stream drip into the bowl.
Ah. Yeah that makes sense.
