Project Icebreaker
Starting a build log here for the evolution of my sig rig Ocean Blue. The NZXT H210i, though a nice case, does not provide adequite radiator space for my build, thus resulting in ~70C ish CPU load temps while gaming or running multiple VMs
So far its been parts collection to move into the new case, and yes i know O11 dynamic in itself is becoming a meme case, but i couldnt resist a dynamic mini snow edition.
The List (all vendors in brackets for where parts are on order from):
Case : O11 Dynamic Mini Snow Edition
Watercooling:
CPU Block : Optimus Foundation AMD CPU block )Plexi/Ni Finish/White Bracket) (Arrived)
GPU Block : Heatkiller IV Nickel Plexi (Arrived)
Radiators : Alphacool Nexxos ST30 White Special Edition 280mm and 360mm (Arrived)
Reservoir : Heatkiller Tube 150 With Blue Accent Struts and DDC Pump Base  (Base On Hand, Waiting For Glass Tube And Struts)
Pump : Liang DDC 35X PWM (On Hand)
Various Fittings: 16mm Hardline Bitspower White (PPCs)
Primochill Loop Prep Kit (Arrived)
Primochill Vue Sky Blue SX(Arrived)
Fans : 7x Corsair LL120 RGB White, 4x Corsair SP140 RGB white (Arrived)
Light Blue Sleeved Cables (On Hand)
Components:
AMD R9 5950X
ASUS Rog Strix B550-I Gaming ITX (On Hand)
Kingston FuryX 64GB 3600MHZ (On Hand)
RX 5700XT Reference (On Hand)
Sabrent Rocket NVMe 500GB (Windows)
Sabrent Rocket 2TB (VMs/Schoolwork)
Crucial MX500 2TB (Games)
Crucial MX300 1TB (Software)
Corsair SF750 Platinum Power Supply (On Hand)
2x Corsair Commander Pro ( 1 Owned, Other Arrived)
1x Lighting Node Pro (On Hand)
1x Corsair RGB Strip Kit (Arrived)
BUILDERS NOTE:
This may take a week or two for everything to arrive, so it will most likely be a rather slow build
Edited by PCSarge
reserved for final images
Edited by PCSarge
Subbed.  I'll just get my water cooling fix from your posts. :lachen:
4 hours ago, Avacado said:
Subbed. Happy to know a part of me will live forever in your build.
Donating organs again I see.
Definitely subbed. Looks like its going to be a sweet build.
i mean, he has to donate something doesnt he?
you cant afford it! we talked about this!
i'm in a debate with myself on tubing size again. stay 1/2 OD or go 5/8 OD, one requires the purchase of fittings the other doesnt (unless i decide to go white fittings which would fit the build)
We talked about sizes. The choice to go large tubing and thus spending money is purely aesthetic and impacts flow/temp in no meaningful way. If your fan box was any larger I would send you a few 16mm fittings and tubing to play with the size difference.
You should watercool your ETF GPU so you can lay the smackdown on all of the other 580's. Right @firedfly 😉
i know its for looks and not performance, but in the case of this build i want the looks to matter as much as the function, my H210i is a butchered mess because i was experimenting.
the only reason i debate 5/8OD tubing so much, is white fittings to go with the theme, and as you've said before, the possibility of the tubing size looking better in the case
Let's see....you were replying to @pioneerisloud.  He's on my ETF team.  water cooling == moar PoINTS.  Yes.  @pioneerisloud should water cool!
Having said that, I'm not water cooling either.
throwing up a little teaser:
Ironically EK wants more for thier block than heatkiller does.
Edited by PCSarge
Nahhh, I'll water cool when I have a nice rig.  None of mine are nice enough. :lachen:
UPDATE #1 : Parts Arrival
Radiators, 140mm Fans, and RGB kit
more coming in the future!
IMPORTANT ANNOUNCEMENT: THIS BUILD WILL BE MY FIRST ATTEMPT AT HARDLINE
Edited by PCSarge
UPDATE # 2 : more parts and coolant.
EDIT: look sideways images just like OCN!
Edited by PCSarge
  • PCSarge changed the title to Project Icebreaker
Update # 3 :
BUILD HAS AN OFFICIAL NAME, SAY HELLO TO ICEBREAKER!
More Parts On Order, including a shiny optimus block!
Edited by PCSarge
This Project has met a delay due to lack of funds, it may be a while before its completed.
Fittings Cost IS a major pain for hardline, especially when i need white ones.
Edited by PCSarge
  • 4 months later...
current build status :
terminally soft tubing until i can afford hardline
Edited by PCSarge
I may be in the minority, but I prefer the look of soft tubing, and I believe your routing of the lines is aesthetically superb! :happy_clap:
I spend a significant amount of timing with messes like:
So, maybe soft tubing looks "normal" to me 🙂.
